'64 with A/C wiring harness clips - NCRS Discussion Boards
  • Albert P.
    • April 1, 2006
    • 205
    Can anyone post pictures of the engine compartment wiring harness location of the clips,straps and plugs supporting the harness;I'm in particular need of the location of the first J-clip along the inner left fender supporting the headlamp harness;thanks.
  • Wayne M.
    • March 1, 1980
    • 6414
    Here's on an early '65
    As nobody's stepped up to the plate in a day, here's my left front fender lip (hood channel) clip. It's also an air car, so both the the headlight and the engine harness (to volt reg and alternator) are held by this clip. This car was an original K66 car, so there should be a third harness under that clip (TI, not yet re-installed). Should add that this is a St.Louis body. '65 TIM&JG says A-body cars had these clips held in place with bonding compound.
    Here's a link (close-up) of the RH clip that fell off, due to excessive sanding of the head in the hood channel.
    Any other pics you need, just let me know.
    • Albert P.
      • April 1, 2006
      • 205
      *Thanks Wayne* *NM*
