C1 Differential - NCRS Discussion Boards
C1 Differential
  • John L.
    • February 1, 1982
    • 35
    C1 Differential
    I have a 4.11:1 posi differential. There is a spacer between the ring gear and carrier. I want to change the ring and pinion to 3.55:1. Can I do it without changing the carrier?
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Yeah, Lose the 1/4" spacer... *NM*
    • John L.
      • February 1, 1982
      • 35
      Re: Yeah, Lose the 1/4" spacer...
      Thanks Dennis
      • Dennis C.
        • January 1, 1984
        • 2409
        John, What you likely have is a...
        ..."3 series" carrier. At some point in time, someone wanted a "4 series" gear set (4.11-1), so they added the spacer to make it fit without changing the carrier. In essense, what you are doing by losing the spacer and going to a 3.55 gear set is going back to the OEM setup. If you're going to spend much time on the freeways, I'd think about a 3.08. Just food for thought. Do what you will and enjoy your car. Best, Dennis
        • Bill B.
          • September 30, 2002
          • 351
          If you went from 3 to 4 series...
          would you ever have to remove some of the carrier internal gusset(s)to make sure the ring gear cleared "all" too? Maybe this is when you go from 3-series to 4-series or it might apply in subject situation? I thought I read something once upon a time as I may be doing the reverse series conversion. But, I don't recall where I read about this.
          • Bob Simard
            Caution
            Check the clearance between the axle shaft ends and the spider gear shafts with the new ratio. Going from a 3.70 to a 3.08 can cause the axle to hit the spider gear shafts and destroy the posi plates and be a real pain to find out what is wrong. Don't ask how I know. I had to shorten the drivers side axle shaft about one-quarter inch.
