69 small guage bezel - NCRS Discussion Boards
  • Brad S.
    • July 31, 2005
    • 227
    What is the part # for the small guage bezel for a 69? I believe it fits 69-71. I have an unbroken bezel with 6491171-69 cast in the part is this correct? Thanks
    • 43193
    Re: 69 small guage bezel
    Brad------
    The numbers cast on the bezel are not the same as the part number for the finished bezel. If you post a picture of the bezel, myself or someone else might be able to ID it for you.
    • Brad S.
      • July 31, 2005
      • 227
      Joe, I don't think I can post a picture. Can you try to explain the differances between the 69- 71 and the 72-76.
        • 43193
        Brad------
        It has to do primarily with the configuration of the upper left portion of the bezel. The 69-71 has a square opening for the seat belt warning light and, below that, a square seat for the seat belt light extinguish push button.
        The 72-76 has a single rectangular opening on the left side which has a single rectangular lens which reads "fasten seat belts"; no pushbutton was used.
        The 1968-only bezel is like 1969-71 EXCEPT that it has a smooth finish rather than the "grained" finish used for 69-71.
        • Brad S.
          • July 31, 2005
          • 227
          Thanks Joe *NM*
