water pump
  • Jeff Wilson (44821)
    • November 1, 2005
    • 272
    water pump
    What is the difference between the 330813 and the 330813P?
  • Joe Lucia (12484)
    • 42936
    Re: water pump
    Jeff-----
    Does the 330813P also have the "GM" trademark prominently displayed on the casting?
      • November 1, 2005
      • 272
      Re: water pump
      I do not see it on the picture at e-bay. I had never seen one for a corvette with a letter at the end of a number before.
      • Joe Lucia (12484)
        • 42936
        Re: water pump
        Jeff-----
        I've not seen a GM pump without the "GM" trademark. It may be that by using the number "330813P", an aftermarket manufacturer is able to "skirt" infringement of a GM trademark (i.e. the number 330813 as applied to a waterpump casting) and, at the same time, imply that the piece is equivalent to the GM piece.
        • Joe Lucia (12484)
          • 42936
          Re: water pump
          Jeff-----
          I did a bit more research on this one. It turns out that some genuine GM examples of the 330813 waterpump did have the "P" suffix after the casting number. I don't know what it signifies, though. However, I do think that these were later examples of the pumps (the 330813 was used from 1972 thru 1982) and I think that the "P" suffix examples were not produced in GM foundries. It's POSSIBLE that's what the "P" suffix denotes.
          Keep in mind that the 330813 was a VERY low volume waterpump casting by GM standards. It was used only for L1972 thru 1982 Corvettes and some MD/HD trucks. I'm pretty sure that earlier 330813 castings were done at Saginaw. However, at some point, they may have decided that such a low volume piece should be out-sourced.
            • November 1, 2005
            • 272
            Re: water pump
            Thanks Joe, as always you have the scoop.
