New issue with the wipers...when the dash switch is turned on, the wiper door opens but the wiper motor does not operate. The wipers do not move. When I pull the manually operated switch under the steering column (right side pull), the wiper door opens as expected. The vacuum side of the mechanism seems to be fully operational....
Looking for step by step guidance on how to troubleshoot this issue? I do not see any loose connections...Do I start at the fuse box?
Any guidance is appreciated.
