58 wiper - NCRS Discussion Boards
58 wiper
  • Brad H.
    • August 12, 2007
    • 724
    58 wiper
    What holds trhe wiper shaft inside the (is it the clutch) Pass side you can pull the wiper assembly with shaft all the way out. And how to fix? thanks brad
  • Erich C.
    • January 31, 2007
    • 137
    Re: 58 wiper
    Check out www.carols62.com/59/wiper_trans.htm . Good site with pictures showing
    the piece disassembled.
    • Brad H.
      • August 12, 2007
      • 724
      Re: 58 wiper
      Great site. Ican take my pass. side wiper blade and shaft out of the transmission with no spring collar or bearing attached. what is it that holds the end of the shaft to the pulley? Do I have to take it apart to get it to hold some how or can you secure the shaft without dismantling? Brad
      • Erich C.
        • January 31, 2007
        • 137
        Re: 58 wiper
        Brad, the shaft is a press fit into the end pulley. As it says on the web site
        some shafts are peened over on both ends and some only on the wiper blade end.
        Is the shaft just loose in the pulley or is it stripped allowing you to turn ( rotate ) the pulley while holding the shaft. If it is just loose you could try using some "green" loctite ( sleeve retainer ) or epoxy. Use a toothpick or something similar and put a thin coating in the hole in the area of the splines only. But before you do that make sure the two pulleys are not stuck together or you will have another problem. If it is stripped the only thing I can think of would be to pin the pulley to the shaft. I would let a machine shop do that if necessary. If it were me I would dissassemble it, clean everything and lubricate it before doing anything else after all it's been together for 50 years.
        P.S be gentle and have patience when working with the pulleys. They don't take kindly to any kind of prying. good luck.
        • Brad H.
          • August 12, 2007
          • 724
          Re: 58 wiper
          erich, the shaft does turn once you push it into the pulleys but would work its way out with wipers operating. Will get helper to watch pulley action when I push down on wiper unit. Does this change anything again thank you Brad?
          • Brad H.
            • August 12, 2007
            • 724
            Re: 58 wiper
