C3 antenna - NCRS Discussion Boards
C3 antenna
  • Jeffrey S.
    • May 31, 1988
    • 1879
    C3 antenna
    Hello all. Does anybody know who the manufacturer is of the reproduction '69 up C3 antennas is? I know they are available at all regular vendors but I would like to find out who makes them for these vendors. Thanks for your help.
    Jeff
    Re: C3 antenna
    Jeff-----
    The antenna mast remains available in SERVICE from GM under GM #370147. However, it's not 100% correct with respect to the originals. For one thing, the size of the ball at the top is a little different and there are other minor differences, too. I don't know if this is the part that's sold in reproduction, or not. Very often, if a part is still available in SERVICE from GM, that's the part that reproduction sources have available, although they may get them from the actual manufacturer rather than GM.
    • Jeffrey S.
      • May 31, 1988
      • 1879
      Re: C3 antenna
      Joe:
      Thanks for the information. Do you know who the vendor is that sells to GM?
      Jeff
        Re: C3 antenna
        Jeff-----
        No, I don't.
          Re: C3 antenna
          If your antenna lead-in cable is factory original, looks closely at the marks on its outer sheath. You might see a 'Ward' designator ink-stamped there which would tie to the original supplier of the antenna mast + lead-in cable...
          • Jeffrey S.
            • May 31, 1988
            • 1879
            Re: C3 antenna
            Jack:
            The cable is original so I will take a good look at it. Thanks for the response.
            Jeff
            • James B.
              • March 1, 1985
              • 217
              Re: C3 antenna
              Joe:
              Regarding the current service replacement antenna for a c-3, do you know when it was introduced? I had purchased a service replacement antenna from GM for my '72 back in the early 1980's. Not sure if it matched the original.
