67 C-2 front springs - NCRS Discussion Boards
  • Dale S.
    • November 12, 2007
    • 1224
    I went thur the archives and found the posts on C-2 springs. I counted coils(10 or 11) and measured diameter(.63 to.65). This appears to be a 3832518 spring. The 67 C-2 has base engine,M-20,C-60,K-19.Am I correct? Thank you Dale
    Re: 67 C-2 front springs
    Dale------
    The GM #3832518 spring was the spring used for cars with F-40/F-41 suspension. It would not have been originally used on the car you describe. The wire diameter of this spring is about .70" and there are 7 total coils.
    The spring that was originally used for your car, GM #3851100, has 11 coils and a wire diameter of about .60". I think that what you have are these springs, although you may be slightly off in your measurement of wire diameter.
    • Dale S.
      • November 12, 2007
      • 1224
      Once again "Thanks Joe" Dale
      • Tracy C.
        • July 31, 2003
        • 2739
        GM #3851100 in the picture.
        • Gerard F.
          • June 30, 2004
          • 3803
          Here's mine Dale
          67 base engine car, tags have 3851100 ED.
          Jerry Fuccillo
          #42179
          Jerry Fuccillo
          • Dale S.
            • November 12, 2007
            • 1224
            Re: Here's mine Dale
            Thanks Jerry, all I have left of my green tag is a piece about 3/4 of an inch long. 3851100 it is. Thanks to all Dale
            • Gerard F.
              • June 30, 2004
              • 3803
              Now the spring code ED
              should not be confused with the lack of spring action present in older men.
              Jerry Fuccillo
              Jerry Fuccillo
              • Dale S.
                • November 12, 2007
                • 1224
                problem Jerry ? *NM*
                • Jim S.
                  • March 1, 1986
                  • 1392
                  Hey Joe,
                  I just got my 66 back from the "body Prep Guy" , so I crawled under to look at my front springs and the drivers side has a yellow sticker with 3888251 on it
                  I cant find that number anywhere ! Any ideas ?
                  Jim
                    Jim------
                    Yes, GM #3888251 was the front spring used for 1966-67 Corvettes with big block and C-60. It may also have been used for 1966 Corvettes with small block and C-60.
                    • Jim S.
                      • March 1, 1986
                      • 1392
                      Joe,
                      Well you can eliminate the "may also" . My car is a C-60 small block.
                      Thanks for checking and letting me know. I fiqured it was close to correct because the number 3888250 was listed in the JG for 66 big blocks , and mine was only one digit off.
                      Now I Know it is original. I also have another item to submit for revision in the "66 JG " as it doesn't mention 3888251 at all ! Thats why I came to you !
                      Thanks again,
                      Jim
