c1 shifter linkage - NCRS Discussion Boards
c1 shifter linkage
  • Susan G.
    • May 31, 2005
    • 136
    c1 shifter linkage
    Does someone know if an original '58 shifter linkage can be installed on a '63 to '65 muncie tranmission. The side casting number on the muncie is 3831707.
    Thanks Susan.
  • Richard T.
    • February 1, 1979
    • 858
    Re: c1 shifter linkage
    The shifter is fine but the rods are different. I've seen some that were cut, bent and welded. Looked like a lot of work. Rich
    • Willard M.
      • August 31, 1979
      • 422
      Paragon, as well as others sells a linkage set designed for Muncies in C1 Corvettes. Much better than trying to Bubba-fix T-10 linkage.
      Bill #2659
      • William C.
        • May 31, 1975
        • 6037
        Not without changing the arms on the transmission, and also using the muncie shift rods. It can be done but it requires some creativity.
        Bill Clupper #618
