C2:67 Haven't seen this baby in 35 yrs - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3803
    I'm ecstatic! Amazingly, I just acquired back my original gas cap for my 67 S/B:
    Here's the bottom with the S under the crud:
    And next to a repro:
    Unlike the repro, this cap vents both ways, you can blow air and suck air through the little hole in the bottom.
    How do I know it's my original. Well here's the story:
    In the early 1970's here in Sonora, CA, I hung around with a pretty wild group of Corvette owners (partying all the time). A few of these guys (excluding myself) were really into modification, big tires, wheel wells, even bigger engines. One of the guys with a 67 427 eventually put his engine in a ski boat, and put a 454 in his Corvette. He eventually sold the boat, and then many years later when he tried to get his engine back, it was long gone with the boat.
    In about 1972, my friend with the 67 427 somehow lost his gas cap. I had been having trouble with teenagers siphoning gas from my 67, so I put an aftermarket locking gas cap on it. (In those days when it was your only car, and you had a rental apartment, you just parked them on the street) Since I had my original gas cap rolling around in my jack compartment, I didn't think twice about giving it to my friend.
    After many years I had lost track of the group and heard he had sold the car.
    It had been sold again to a local restorer just this last year, and this summer I ran into it at a local charity car show. It was beautifully restored, but NOM, so I new it wasn't NCRS material, but a real nice car.
    I contacted the present owner and restorer, told him the story and asked if he still had the gas cap it came with. Oh, it was somewhere around the shop, somebody had painted it, I'll see if I find it, if I hadn't thrown it out.
    Well, yesterday he found it, and I traded some future plating and a 67 JG for it.
    So guess what my next project will be.
    Having fun
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
  • Rick S.
    • January 1, 2003
    • 1203
    Re: C2:67 Haven't seen this baby in 35 yrs
    Jerry,
    Great Story
    • Gerard F.
      • June 30, 2004
      • 3803
      Pardon me, it's SM in two circles
      Started cleaning it up with steel wool and found the trademark on the bottom.
      Kind of a circular font of "SM" within two circles. Quite different than the single S on the repros.
      Looks like mine was stamped at an angle or the parts of the circles wore off.
      Not sure this is going to survive replating, so I might just mask around it.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Don S.
        • February 1, 2000
        • 476
        Hooters
        Jerry-- I haven't seen anyone get so excited about a gas cap in all my life. You need to get out more often. Maybe a trip to Hooters.
        • Gerard F.
          • June 30, 2004
          • 3803
          Re: Hooters
          Since there's no Hooters around here, I guess I'm relegated to gas caps.
          But the gas cap did bring back memories of a lot wilder times.
          See what this hobby has done to me, made me a fanatic. Darn NCRS.
          Jerry Fuccillo
          #42179
          Jerry Fuccillo
            Your cap is a little too pitted/worn...
            to correctly see the early logo, Jerry. It's NOT SM enclosed inside two circles!
            If you look carefully at an original in better condition, you'll see the inner 'circle' isn't a full circle. It's actually a large 'C' that's enclosed by an outer circle. That makes the emboss read 'SMC' for Stant Manufacturing Corporation in a stylistic rendering....
            • Jeffrey S.
              • May 31, 1988
              • 1879
              Re: Hooters
              Jerry:
              Those caps come apart quite easily and you can plate just the outer piece without the spring or inner piece attached. I have done several and would be happy to ghive you some hints if you have never done it before.
              Jeff
              • Jeffrey S.
                • May 31, 1988
                • 1879
                Re: Hooters
                Jerry:
                Jeff
                • Joe R.
                  • March 1, 2002
                  • 1356
                  Re: Hooters
                  Hi Jeff:
                  When you plate the bottom half, do you disassemble the smaller inside valve (the one that opens when the pressure outside the tank is higher than inside)? If so, how do you get it apart without disturbing the "rivet" in the center?
                  • Joe R.
                    • March 1, 2002
                    • 1356
                    Re: Hooters
                    Hi Jeff:
                    • Jeffrey S.
                      • May 31, 1988
                      • 1879
                      Re: Hooters
                      Joe:
                      I don't do any disassembly of the bottom part. In fact, If the at part is in good shape I just leave it alone. I don't believe that plating this piece using the Copy-Cad system from Caswell would hurt any internal parts since no real cadmium or corrosive chemicals are used.
                      Jeff
                      • Jeffrey S.
                        • May 31, 1988
                        • 1879
                        Re: Hooters
                        Joe:
                        Jeff
                        • Gerard F.
                          • June 30, 2004
                          • 3803
                          Re: Hooters
                          Hi Joe,
                          I plan disassembling the top and bottom half, and then plating each as one piece. Don't think the plating solution is going to hurt the little check valve on the bottom.
                          Jerry Fuccillo
                          #42179
                          Jerry Fuccillo
                          • Gerard F.
                            • June 30, 2004
                            • 3803
                            Re: Hooters
                            Hi Joe,
                            Jerry Fuccillo
                            #42179
                            Jerry Fuccillo
