C3 71 shocks - NCRS Discussion Boards
C3 71 shocks
  • Lyndon S.
    • April 30, 1988
    • 1027
    C3 71 shocks
    I am going over some detail items on my 71 LS5. One is shock absorber codes. Want to make sure the codes for a standard suspension car is. Front is a DG and VS for the rear shocks. Also what is the general location that one finds the codes placed on the shocks. Thanks
    Kelly
  • Lyndon S.
    • April 30, 1988
    • 1027
    Re: C3 71 shocks
    Does anyone know the approximant size of the labels for the shock. I am going to make some as I can not find any with the codes on them that the JM calls for.
    Kelly
    • Lyndon S.
      • April 30, 1988
      • 1027
      Re: C3 71 shocks
      Kelly
        • 15573
        Re: C3 71 shocks
        Kelly,
        I can measure the labels on my 1970, however they are not the original labels -- they are reproductions. I wish I could remember the company i got them from, it is in Northern Illinois. I should see the vendor at the Chevy Vette Fest show in Rosemont, IL, this weekend -- if you can wait. I'm not sure he has the right codes for your 1971, but he made them from GM's code sheet -- which he showed me back in the day when I was TL and he was partners with Tim Partridge in the wire harness and erstwhile shock absorber venture.
          • 15573
          Re: C3 71 shocks
          Kelly,
          • Lyndon S.
            • April 30, 1988
            • 1027
            • Lyndon S.
              • April 30, 1988
              • 1027
                • 15573
                Re: C3 71 shocks
                The labels I have -- which again, I must point out are reproductions -- measure 1-inch wide and 5/8-inch high.
                I hope someone reading this is in a position to measure some original labels, just so we can be sure of the exact dimensions.
                  • 15573
                  Re: C3 71 shocks
                    • 3415
                    Re: C3 71 shocks
                    Kelly,
                    I have a good photo of the right rear shock label from my 71. The code was long gone but the paper label was in relatively good condition. It's about 3 inches down from the top of tube and faces the center of the car but turned slightly to the rear. Is this, or is there, a typical location?????
                    PS: A judge could see it in that position if he really wanted to.
                      • 3415
                      Re: C3 71 shocks
                      Kelly,
                        • 15573
                        Re: C3 71 shocks
                        On the rears I usually see them (when I used to do Chassis ) on the upper cover -- the larger diameter part for the standard shocks. Almost anywhere on that will do, but most guys installing reproductions put them where the judges can see them.
                        On the fronts don't fret about it -- one can almost not see the labels anyway.
                          • 15573
                          Re: C3 71 shocks
