Oil Pump GM3732798 - NCRS Discussion Boards
Oil Pump GM3732798
  • J M.
    • July 31, 2005
    • 60
    Oil Pump GM3732798
    This came out of my 66 327/350. It's the casting number on the pump. Is this just the standard SB oil pump? Thanks.
    Re: Oil Pump GM3732798
    Dan------
    Yes, it's a standard volume pump casting. However, there's no way to tell if it's standard pressure or high pressure----both pumps used exactly the same body and cover. The only difference is the relief spring installed in the cover. If the pump is original to the car, it will have a standard pressure spring installed.
      Dan------
