window crank seals-'64 - NCRS Discussion Boards
  • Albert P.
    • April 1, 2006
    • 205
    Does anyone know if the window crank seals were installed behind the door paper vapor barrier or between the barrier and the door panel?thanks
  • Albert P.
    • April 1, 2006
    • 205
    ANY help would be appreciated *NM*
    • Albert P.
      • April 1, 2006
      • 205
        Re: window crank seals-'64
        Garth -
        That seal goes over the regulator shaft AFTER the vapor barrier is installed, and BEFORE the door trim panel goes on.
          Garth -
          • Albert P.
            • April 1, 2006
            • 205
            Thanks John *NM*
            • Albert P.
              • April 1, 2006
              • 205
              Thanks John *NM*
              • Alan Drake
                Yes that's where they go, however my Mar64 never had them. Now the AIM calls for them and lost credit for not having them at Nationals. Now have some repro's and will put on, but again my car never had them. Owned since Aug 67 and other owners never removed door panels. At National was an early 64 never touched and panels where removed under the tent, showed the paper and NO seals. I would add them since they can be removed later.
                • Alan Drake
