1966 Clutch rod jam nuts - NCRS Discussion Boards
  • Tony C.
    • February 29, 2008
    • 117
    • May 31, 1974
    • 8365
    Re: 1966 Clutch rod jam nuts
    i'd black phosphate them. think they may still be available from GM. mike
      • May 31, 1974
      • 8365
        Those jam nuts are the same nut used to secure the battery positive cable to the starter solenoid stud, and the nuts used on the bolts for the big-block rear stabilizer bar link ends to the bar and to the bracket on the trailing arm.
            • 43193
            Mike and Tony------
            The original nuts, GM #124829, are still available from GM (for about 4 bucks, each). However, the GM finish spec for the nuts is zinc plated. It's possible that finish changed over time.
              • 43193
              Mike and Tony------
                Joe -
                The '67 JG also calls them out as zinc-plated in the rear stabilizer bar link bolt applications.
                  Joe -
                    • 43193
                    John------
                    Yes, and I'm 100% sure that in the battery cable-to-solenoid application they were zinc plated. So, I'd guess they were all zinc plated.
                    I think I changed the ones on my car to standard thickness nuts years ago when I changed the clutch rod (either that, or they were always standard thickness). I don't recall what the originals were (assuming that the ones on it now are not original).
                      • 43193
                      John------
                        • 43193
                        Addendum
                        One other thing: I can't figure out why they ever used the thin jam-style nut for the clutch rod application. In general, standard thickness nuts are used for "structural" applications except for special reasons (like clearance problems). There is no clearance problem with the clutch rod nuts. I would think that the extra thread engagement (and strength) provided by standard thickness nuts would be useful in the clutch rod application and no benefit, whatsoever, would be achieved by using jam nuts. That may be what I was thinking when I changed them (assuming that I did change them).
                        In general, jam nuts are used for "locking" purposes, not "structural". Of course, the battery cable application requires little strength and the thinner jam nut might be otherwise useful. So, I can understand why the jam nut was used there.
                          • 43193
                          Addendum
                            • May 31, 1974
                            • 8365
                            Re: Addendum
                            joe: i was told, years ago by a Bar Brother( crow, wreck and pry), that the nut thickness, once it exceeds the diameter of the bolt, is a waste of nut threads. now i'm here to tell ya, these Bar Brothers weren't MIT grads. what say ya? mike
                              • May 31, 1974
                              • 8365
                              Re: Addendum
