C3-Alternator Numbers
  • Greg F.
    • February 21, 2007
    • 253
    #1
    I have these numbers on my 71 vette. I believe it is the original alternator:
    1100544 61A
    1B6 12VNEG
    Can someone tell me what each number means, please.
    thanks,
    Greg
    • 42936
    Re: C3-Alternator Numbers
    Greg-----
    Yes, it could well be the original alternator if the car has C-60. The first number is, of course, the alternator part number which is correct for a 1971 Corvette. The "61A" means the alternator is rated at a maximum output of 61 amps. The 3rd set of numbers, "1B6", is the date code. It decodes to February 6, 1971. The last set of numbers of course means 12 volt, negative ground which all 1955-2008 Corvettes (except 1955 with 6 cylinder) are.
    By virtue of the date code, your car would have to have been built after February 6, 1971.
      • 42936
      Greg-----
      • Greg F.
        • February 21, 2007
        • 253
        Thank you Joe!
        My car was built on February 16, 1971 so it all lines up.
        What does C-60 mean?
        Thank you again!
        Greg
        • Greg F.
          • February 21, 2007
          • 253
          Thank you Joe!
          Thank you again!
          Greg
            • 42936
            Greg-----
            C-60= air conditioning
              • 42936
              Greg-----
              • Greg F.
                • February 21, 2007
                • 253
                Re: C3-Alternator Numbers-Joe, It is-Thnx *NM*
                • Greg F.
                  • February 21, 2007
                  • 253
