My recently purchased 56 Vette stops running after 15-20 minutes. Cause is lack of spark. Discovered that coil is very hot at that time and there is some oil leaking out of the top it. Replaced coil. New coil gets hot also, hotter than other coils I am familiar with. It appears to be hooked up properly, ignition wire to ceramic resistor, resistor to + side of coil, - side of coil to distributor. + side of coil is shared with another wire that goes into wire harness. Engine won't start with this wire disconnected from coil, starts right up when connected.
Coil gets so hot I'm sure its life will be very short. What's the problem? Are there different resistors I should try???
