radiator shroud for 56/57 vs 58/59 - differences? - NCRS Discussion Boards
  • Ian G.
    • September 3, 2007
    • 1114
    The fan shroud on my 59 is the three piece type off a 60-62, so I'm looking to replace it with one correct for a 59. I've noticed some repro companies have a single top shroud available for 56-69 while others (like paragon) have one for 56/57 and another for 58/59, while they all seem to use the same bottom pieces for 56-59. So I read that the bottom parts are the same for 57-59 (4 parts on bottom for 56 right?), but what is the difference (if any) for the top of the shroud between 57-59? I plan to get an original, just want to know if I get one from a 57 or 58 if there is any difference.
    thanks!
  • Richard T.
    • February 1, 1979
    • 858
    Re: radiator shroud for 56/57 vs 58/59 - differenc
    The 56/57 upper shroud mounts to the support with two bolts. The 58/59 uses three bolts. Rich
    • Richard T.
      • February 1, 1979
      • 858
