Master Cyl squirting a mile high... Ever seen it? - NCRS Discussion Boards
  • andy#34338
    Put a rebuilt master cyl on my 60 and noticed fluid squirting out the both holes in the cap. Took the cap off, hit the breaks and fluid squirts up and out filler hole up 10 or 12 inches high. I drained and removed the master cyl and worked it by hand. The fluid is squirting up from the little hole in the bottom of the cyl below the filler hole (fluid intake hole?) Could the wrong plunger have been put in this master cyl? Anyone ever seen this before?
    Andy
