Question on the voltage regulator,headlight and regulator harness, and regulator mounting;
My regulator is mounted on radiator support,no evidence of it ever being on the inner skirt;the harness to the headlights has a ground wire terminating on the regulator and the harness to the regulator also has a ground wire terminating on the regulator mount; the horn relay is also mounted on the radiator support, above the regulator; is this correct? Anyone have a picture showing the regulator mounting and wiring harness ground connections? Thanks.
