Does anybody make a quality set of midyear window cranks? I got some from CA that were Tiwan imports and they fit like crap! The slots for the clip were cut in the wrong place, the slots were not even parallel with the face of the crank, and the bore was a loose fit on the splines of the shaft. The cranks left a gap between the door panel and were loose as a goose on the shaft. It was alomst impossible to remove the cranks with a crank clip tool since the slots do not line up with the back face of the crank like the original GM cranks do.
I notice in looking around, that nobody seems to sell a domestic crank anymore, and it appears that all cranks are imported. I would prefer 67 cranks, but will settle for 66 style cranks if the fit is good. I hate to just keep ordering cranks from every vendor hoping for a set that fits, so any input from those of you that have bought cranks would be appreciated. I see service replacement cranks for 67's with clear knobs everywhere, but I have never seen a matching set of vent window cranks. I suppose that it is not lkely that I will since cars after 67 did not use vent cranks, Any help would be appreciated. I need one set for my resto-mod and a set for a friend's 67 coupe that I am restoring. I would be looking for one set of white knob cranks and one set of blacks, or 2 sets of 66 style cranks.
Regards, John McGraw
