I have a few questions regarding changing the gear oil in my '65 manual transmission. First - when I attempted to drain the transmission I could not find a drain plug, however I did find a bump out somewhat below and to the right of the fill plug. On the bump out is the outline of a circle and it appears this is where a drain plug should go. Am I missing something? Why wouldn't there be a drain plug?
Also - what are the pros / cons using synthetic gear oil?
Thanks in advance for your response.
