Guys,
I bit ago you all provided some excellent advice on transitioning my '63 brake system from traditional Dot 3/4 fluid to Dot 5. Someone mentioned "power bleeding" in one of the posts, and somewhere I read that bleeding with Dot 5 should not be done the same way as with traditional Dot 3/4.. (the old pump the pedal and hold it down while someone else bleeds the cylinders routine).
Can you guys provide some guidance on how to bleed the system with Dot 5.. and if a power bleeder is recommended, any suggestions as to which one out there is worth investing in???
Thanks in advance!!
Joel
Thanks in advance!!
Joel
