C2 Flight Judging Deleted Options - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    A local gentleman has a '66 L79, originally from California, with original window sticker, warranty book w/P-o-P, and cylinder case assembly stamping suffix all indicating K19 (air injection reactor).
    Trouble is, all (and I mean ALL) of the smog stuff has been removed, and replaced with proper non-K19 equipment. He asked me how it would judge, and the more I got into the judging sheets, TIM and Judging Reference Manual, the more I felt this was a question best put to the black hats.
    I am aware of the draconian "subject to full deduction" as it pertains to N14, N40, J50, etc. additions or deletions, but (in this case) if the only indicator is the assembly stamp suffix code (assuming that he doesn't present the window sticker and that the P-o-P is not decoded during flight), I can see two outcomes.
    1. Assume that the suffix is a factory error. Should maybe lose half of the 25 points for assembly stamping. Everything else in the engine compartment is correct non-A.I.R.
    2. But, if it is deemed that the suffix is correct, then full deductions are in store for the rest of the K-19 equipment that is not present, and items that are present but in their non-K19 version. [ie. carb, air cleaner base, exhaust manifolds, air pump, hoses, belts, brackets, pulleys, etc.) In this latter example, the points hit could be massive.
    Would like your opinions.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C2 Flight Judging Deleted Options
    outcome # 2. mike
    • Mike M.
      • May 31, 1974
      • 8365
      outcome # 2. mike
      • Roy B.
        • February 1, 1975
        • 7044
        Well! If he removed it and no one can tell he should be OK in my opinion // if made up options installed in other Corvette cant be detected and get top points why not him.
        • Roy B.
          • February 1, 1975
          • 7044
            Roy-----
            That would work EXCEPT for the fact that the engine has the "with K-19" suffix code. That's the "fly in the ointment".
              Roy-----
              • William C.
                • May 31, 1975
                • 6037
                Agree with Mike!
                Engine, assuming an original pad, would get full credit, and the missing items would be scored as missing.
                Bill Clupper #618
                • William C.
                  • May 31, 1975
                  • 6037
                  Agree with Mike!
                  Bill Clupper #618
                  • Mike M.
                    • May 31, 1974
                    • 8365
                    roy- the engine pad's suffix will call out for a K19 option. point is roy, he probably doesn't want to remove the suffix from what is said to be the original engine.Hence, most observer judges would pick up on the K19 suffix and absence of smog pieces underhood.i seem to recall the word "preservation" in the stated goals the founders of NCRS chose when they wrote of the purpose of the club. mike
                    • Mike M.
                      • May 31, 1974
                      • 8365
                      • john daly
                        According to the NCRS spec guide the suffix is "HD" for L79,K19 and 4 speed and "KH" for K19 A/C,P/S and four speed.
                        • john daly
                          • Michael W.
                            • April 1, 1997
                            • 4290
                            Perhaps the word 'option' is not
                            appropriate in this case. I believe that K19 was mandatory for California bound L79.
                            • Michael W.
                              • April 1, 1997
                              • 4290
