1955 braided ignition wires - NCRS Discussion Boards
  • Wayne C.
    • November 1, 1978
    • 289
    Re: 1955 braided ignition wires
    Dave, since I don't have a 55, nor any manuals for one, I'm afraid I'm a dummy flying blind, I'm only relaying info I get here... what are the "original J clips"? I'm thinking they may be some sort of clip that holds/guides the spark plug wires and has a mounting screw that goes in the same hole (below/between the spark plugs) that the (later) heat shields use? Do you know if/where repros of the "J" clips are available?
    Thanks.
    • Wayne C.
      • November 1, 1978
      • 289
      Thanks.
      • Dave Suesz
        #18
        You might be able to get these clips from MaryJo or Grossmuller, but frankly they would be easy to make. As far as I know, they were used on the Corvette only, in 1955 only. Pretty narrow target.
        • Dave Suesz
          #19
          • Wayne C.
            • November 1, 1978
            • 289
            #20
            Easy to make, maybe ...but only if you have an example to copy! :>)
            Again, remember, I've never seen a 55 Corvette V8 put together correctly, I'm asking for a friend, and so I can't visualize it. I don't have an AIM, and Noland's book doesn't show the spark plug wire routing below the heads, and Grossmueller's website doesn't seem to have illustrations nor mention a J clip.
            Does the one on this web page look like the one you are referring to:
            Are there 4 of them and do they simply hold the braided spark plug wires against the side of the block and attach where I assumed (where the later heat shields attach)? When installed on the block, is the "J" hook at the top or at the bottom?
            Thanks!
            • Wayne C.
              • November 1, 1978
              • 289
              #21
              Thanks!
              • Roy B.
                • February 1, 1975
                • 7044
                #22
                Re: 1955 braided ignition wires *NM*
                • Roy B.
                  • February 1, 1975
                  • 7044
                  #23
                  • Wayne C.
                    • November 1, 1978
                    • 289
                    #24
                    Re: 1955 braided ignition wires THANKS! *NM*
                    • Wayne C.
                      • November 1, 1978
                      • 289
                      #25
                      • Dave Suesz
                        #26
                        1955 braided ignition wire routing
                        The rear clip, which holds three wires and two grond leads.
                        • Dave Suesz
                          #27
                          • Dave Suesz
                            #28
                            1955 braided ignition wire routing .2
                            This is the front wire clip, which holds one wire and two terminals.
                            • Dave Suesz
                              #29
                              • Dave Suesz
                                #30
                                1955 braided ignition wire routing .3
                                another view, showing the offset.
