1967 SB Shroud - NCRS Discussion Boards
1967 SB Shroud
  • Tom F.
    • September 30, 1995
    • 14
    1967 SB Shroud
    Hi Gang, I know this has been discussed several times, However, My unrestored 1967 shroud was painted in a earlier time. When I stripped the paint off the fiberglass was more medium/lighter gray than dark gray or black. When I looked at other SB cars at various events the shrouds all seemed to be painted or black out, some way more than others. Can anyone clear up the finish, the black out, the dark or light gray fiberglass etc. As far as I know the shroud is original
  • Kent K.
    • December 1, 1982
    • 1139
    Re: 1967 SB Shroud
    Tom ---- After the black fiberglass is cleaned, it appears nearly medium gray. It could be very lightly clear coated with non-glossy laquer to return it to a black appearance. Some judges may catch it and deduct a point or two.
    Regards, Kent Keech
    Kent
    NCM Founder - Member #718
    • Kent K.
      • December 1, 1982
      • 1139
      Re: 1967 SB Shroud
      Regards, Kent Keech
      Kent
