air vents - NCRS Discussion Boards
air vents
  • Jim S.
    • March 1, 1986
    • 1392
    air vents
    Hey guys, what gives with my two outside air vents.
    The right side has the door with the pivots (as shown )once you remove the Black air diverter.
    The left , after the black cover is removed , appears to have a seal with a small square cut out of it to allow the cable to enter . The seal is all caulked up . It seems that even when the vent is opened all the way , only a small amount air would pass through it.
    It is an Air car if that makes any difference. Or as I suspect has Bubba been at work here ?
  • Donald T.
    • September 30, 2002
    • 1319
    Re: air vents
    That Bubba guy sure does get around! Not sure what he was trying to accomplish with this modification, but that ain't the way the General designed it.
    • Donald T.
      • 1319
      Re: air vents
      • Wayne K.
        • December 1, 1999
        • 1030
        Re: air vents
        Bubba could have had a water leak and stopped the flow.
        • Wayne K.
          • December 1, 1999
          • 1030
          Re: air vents
          • Wayne M.
            • March 1, 1980
            • 6414
            Re: air vents
            Jim -- Your described LH is actually RH (& vice-versa). On C2's, the LH kick pad vent is the same, C60 or not. On your shot of the LH, all seems normal, except that with the vertical angle that the bowden cable is attached to the door, it would probably not open. Of course, with the black plastic deflector grille in place, and the cable anchor attached to the tab, it will then allow push/pull action from the proper angle.
            Now for the passenger side, which is radically different from the non-air car. The auto-load pic is off my early '65. I've shown the delector door in the RH plenum chamber door partially open so you can see the dense foam that is glued to the door, with a cut-out in the foam to allow the pivot arm to be attached to the door with rivets.
            I can't fathom what Bubba was up to in your case, but the "fix" would certainly reduce air flow, whether from outside, recirculated from inside or a mixture of both. In the glued-close position shown in your pic, the system would be set to outside air, with only the little cut-out allowing a bit of inside circulation.
            These are expensive items if can't be restored; a plenum just sold on eBay for $ 611.
            • Wayne M.
              • March 1, 1980
              • 6414
              Re: air vents
              • Jim S.
                • March 1, 1986
                • 1392
                Re: air vents
                Thanks Don and Wayne,
                Wayne, yes you are correct , I crossed my left and right pictures. Sorry about that !
                Judging from your picture ,and I appreciate the effort because I know how hard it was for me to get mine , it appears that Bubba took the foam off the door and glued it to the opening. The whole assembly is still there , just Mickey-Moused with a bit ! I fiqured that an A/C car may have been done differently, but I didn't think that the foam glued in place looked right !
                I guess I will have to do some rehab on both of them as the rubber or foam edge on the "left one" is also pretty dried out . The hazzards of an Arizona car. No rust, but lots of dried out rubber and such!
                Still not having as much "fun" as Gerald Fuccillo, but moving along,
                Jim
                • Jim S.
                  • March 1, 1986
                  • 1392
                  Re: air vents
                  Jim
                  • Jim S.
                    • March 1, 1986
                    • 1392
                    Re: air vents
                    Both Waynes,
                    I fiqured it out ! As Wayne Kindschy said a water leak may have been the reason Bubba sealed the door shut.For whatever reason, Judging from Wayne Midkiff's picture it appears that he tried to seal it shut while closed and eventually the foam stayed while the door seperated from the foam and continued to open and shut whenever pulled .
                    The cover shown in my picture is definately a foam type material. Add the little cut out and it matches perfectly to what it is supposed to look like . I am fairly sure that is what has happened.
                    Thanks again all,
                    Jim
                    • Jim S.
                      • March 1, 1986
                      • 1392
                      Re: air vents
                      Both Waynes,
                      Thanks again all,
                      Jim
                      • Jim P.
                        • August 31, 2003
                        • 89
                        • Jim P.
                          • August 31, 2003
                          • 89
                          • Jim P.
                            • August 31, 2003
                            • 89
                            Re: air vents
                            After:
                            • Jim P.
                              • August 31, 2003
                              • 89
                              Re: air vents
                              After:
