67 sidepipes - NCRS Discussion Boards
67 sidepipes
  • Don S.
    • February 1, 2000
    • 476
    67 sidepipes
    The black book shows option as N14. Does anyone know if these are still available from GM or if they are repro'd and or what the correct part #'s are.
  • Donald T.
    • September 30, 2002
    • 1319
    Re: 67 sidepipes
    Don,
    The sidepipes are long discontinued from GM. If you want NOS then Allen's has them. Be prepared to pay $$$. Any of the usual vendors carry reproduction sidepipes and hardware; just check the catalogs. Note that the repros do not sound like originals and are very loud. Forget about listening to the radio or talking to your passenger. Also, be prepared to take a major point hit if the car is not an original sidepipe car and you have it judged.
    • Donald T.
      • 1319
      Re: 67 sidepipes
      Don,
      • John M.
        • January 1, 1998
        • 813
        Re: 67 sidepipes
        Don, Check these guys out. They are close to original, close but not the same and not expensive compared to the Allens NOS which must be partially fabricated.
        OEM replacements for C2 side pipes. Made and manufactured in the USA from the highest quality materials available - hand-welded and jig-fitted. Whether it's small block or big block we have you covered at HighFlo Performance!
        • Bill S.
          • January 31, 2007
          • 396
          Re: 67 sidepipes
          i checked these out. the head pipes are carbon steel but the chambered mufflers are aluminized resulting in a non correct sound. i finally found a set or NOS sitting since 1967.
