When did the drums change from having the fins on the vertical surface wrapping over the horizontal edge...to only having the fins on the vertical side of the drum.
Were the original finned 1956/57drums with the fins that wrapped around and over the top of the drum..only used with 15 x 5 1/2 inch wheels...in order to clear the fins on the face of the drum?
Many early drums surface with the top fins milled off to clear the wheel...later drums were made without these top fins.
I suspect this happened in 1958 or 1959 production...however..I have pictures of the March 1957 Sebring factory racecars that already had the later or milled drums!
Thanks for any insight on this running change.
Joe Trybulec
trybulec@aol.com
Joe Trybulec
trybulec@aol.com
