Camaro question - NCRS Discussion Boards
Camaro question
  • Andrew Strauss
    Camaro question
    Does anyone know what block casting would be correct for 375 hp 396 in a x-10 69 Camaro?
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Camaro question
    Could be one of two, I believe. Early cars would have used 3935440 ( Through August production of 68 ) after that should be 3955272
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Joel Falk
      Re: Camaro question
      Very late cars could also have a 3969854
        Re: Camaro question
        Andrew -
        No such thing as an X-10 code - did you mean Z-10? An original big-block car would carry an X22 or X66 code if it was built after mid-December, 1968.
        • Paul G.
          • August 31, 2006
          • 66
          Re: Camaro question
          John, would the X code be on Norwood cars only?
          • Rick S.
            • January 1, 2003
            • 1203
            Re: Camaro question
            Paul,
            Rick Wagnor called me and said for you to get back to work.
            Rick
            • Jay G.
              • August 31, 1993
              • 398
              Re: Camaro question
              Don't mean to butt in. The Norwood cars recieved X codes after Vin Numbers 54440 Apx. Mid Dec 68. The Van Nuys and Los Angles built cars did'nt recieve X codes at all. Thats how some of these questionable LA built cars become SS 396's or Z-28's. No X- codes.
                Re: Camaro question
                Paul -
                Yup, Norwood cars only - should have mentioned that in my original post.
                • Mark D.
                  • June 30, 1988
                  • 2142
                  Re: Camaro question
                  My original motor 05A Norwood built X22 L78/L89 is a 272 block.
                  Mark
                  Kramden
