c1 keys - NCRS Discussion Boards
c1 keys
  • paul bowers
    c1 keys
    does the 57 have just one key, if not what keys fit what?
    thanks
    paul
  • Steve H.
    • November 1, 1996
    • 118
    Re: c1 keys
    Paul,
    My 56 has one key that fits all locks.
    Steve
    • Verle R.
      • March 1, 1989
      • 1163
      Re: c1 keys
      Paul,
      These days most real, unrestored 57's just have one key, and one key will fit all.
      I don't remember the exact number but in those days there were only about a dozen or two different key codes. When a key and switch get well worn probably half of the keys out there will work the lock.
      The key should open all locks, door, ignition, trunk and glove box.
      Verle
      • Richard T.
        • February 1, 1979
        • 858
        Re: c1 keys one key ! NM *NM*
        • Jeffrey S.
          • May 31, 1988
          • 1879
          Re: c1 keys
          Verle:
          A couple of years ago a friend locked his keys in the trunk of his '57 Corvette during the Woodward Dream Cruise. The next day we were at an A&W and another '57 came in. My friend borrowed his keys and they opened his trunk.
          Jeff
          • paul bowers
            Re: c1 keys
            thanks verle ,and guys
            so if my trunk lock is a different key do you think a local lock co. could take my trunk lock and change it so other key would work
            paul
            • Verle R.
              • March 1, 1989
              • 1163
              Re: c1 keys
              Paul,
              Any competent locksmith can change the tumblers in a lock to match your ignition/door key....no challenge at all.
              It will save you money and time if you remove the trunk lock and take it in their shop. Personally, I would not want someone else taking tools to my 57.
              Verle
              • Roy B.
                • February 1, 1975
                • 7044
                Re: c1 keys
                I been to Corvette meets and just for kicks I asked owners to use my 55 Corvette key in them and %75 of the time it worked
                • Gary B.
                  • February 1, 1997
                  • 6979
                  Keys
                  Paul,
                  For C1 and C2 Corvettes, from 1953 thru 1966 there were only 1500 different door/ignition key combinations. Key codes ranged from 8000 to 9499 and those same codes were repeated for all years from '53-'66. Given the total number of Corvette made between 1953 and 1966, there is a good chance that a given key will open and start dozens of different C1 and C2 Corvettes, thru '66. Key things got somewhat more secure starting in 1967.
                  Gary
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    Re: c1 keys
                    Just to add to this, my 59 had 2 different keys when I bought it 20+ years ago, and neither worked on the glovebox. I bought some old chevy tumblers at a flea market, took them apart and removed the little brass tumbler bits by removing the ss cover plates. Took my glovebox and ign locks apart and found the right comos of bits to make everything match. I then had 1 key for everything.
                    Rich
