Connectors - NCRS Discussion Boards
Connectors
  • Albert P.
    • April 1, 2006
    • 205
    Connectors
    Need info on the type of connectors used on ballast resistor and coil;are they standard non insulated spade connectors? Is the bottom of the ballast resistor a flag connector? Are the 2 pink wires on the coil attached in one connector?car is '64;thanks
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: Connectors
    This is what you need...Connectors are spade.
    Both pink wires at coil are in one connector.
    • Albert P.
      • April 1, 2006
      • 205
      Thanks Steve *NM*
      • William C.
        • May 31, 1975
        • 6037
        Re: Connectors
        Just fyi, originals did not use heat shrink tubing over the crimp, I think the heat shrink in the picture is to cover an incorrect crimp configuration on the terminal. No sleeve is called for on the print.
        Bill Clupper #618
        • Stephen L.
          • May 31, 1984
          • 3148
          Re: Connectors
          Bill, on a 67, the connectors on the ballast resistor had heat shrink on them.
          Below is a photo of my original underhood wiring harness (removed from car due to condition). The pink wire connector on the left connects to the ballast resistor. The 2 pink wire connector(no heat shrink) connects to the coil.
          In my previous photo the wire coming from the ignition (bottom wire) is an original with the heat shrink. The top wire is from a reproduction harness that replaced my original shown in this photo.
          • William C.
            • May 31, 1975
            • 6037
            Re: Connectors
            Partially correct, '67 was the first year to use a cover over the crimp, but it was not heat-shrink, it was rubber tubing, 3/4 inch long, 9/64 OD that was streched over the terminal crimp area. The tubing thickness is about twice as thick as heatshrink, easy for a judge to pick up if looking. Years previous to '67 leave the crimp area uncovered.
            Bill Clupper #618
            • Dale S.
              • November 12, 2007
              • 1224
              Re: Connectors
              Steve, My 35k 67 coupe has the shrink wrap as per your 2nd photo. It would be interesting to hear from others on this. Jerry F. etc. Maybe not just 67 but all C-2's. Dale
              • Stephen L.
                • May 31, 1984
                • 3148
                Re: Connectors
                I guess I used the term shrink wrap loosely.... It probably is a rubber tube. It definitely is NOT the shrink tubing that has a smooth surface. However the tubing used on my reproduction harness is not smooth either so it probably is rubber tubing. I've had this car top flighted at 3 regionals over the past 2 years and not one judge commented on this wiring. I did get gigged for the backup lite wiring justifiably so telling me they looked at this area.
                • Dale S.
                  • November 12, 2007
                  • 1224
                  Re: Connectors
                  Looks like that answers that. D/
                  • William C.
                    • May 31, 1975
                    • 6037
                    Re: Connectors
                    Wiring prints show '67 is first your for the sleeve, 63-66 did not use it.
                    Bill Clupper #618
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      Re: Connector Wire Insulation Colors
                      Garth --- in addition to connector comments by others as pertains to your '64 (no sleeve on ballast resistor; single sidewise spade [as Steve's pic shows] that attaches the two wires to the +ve coil terminal), your 1964 should have black with pink stripe wires at these 2 locations (engine harness and main under-dash harness).
                      Don't believe they went to solid pink until sometime in 1965 (certainly not early '65). Also, your backup switch wiring (both from switch and from main under-dash harness should also be black with a pink and black with a green stripe.
                      • Albert P.
                        • April 1, 2006
                        • 205
                        Thanks wayne *NM*
