When I removed the original 7029204 quadrajet from my stock intake manifold (1969 aluminum intake 427/390 hp), I found a base gasket, stainless baffle (gasket), then another base gasket. Can someone verify if this is correct or should I have a base basket on the intake, then the stainless baffle and then the carburetor itself and not the 2nd base gasket? Yes I did look in my poor reproduced copy of the AIM.
Thanks in advance for your help. Reason for removal of carburetor--inlet fitting stripped and gas squirting onto intake mainifold. Yikes!!!
Jim Blakely #3742
Jim Blakely #3742
