C-1 Specs Wanted for 1960 283 / 290 HP Cam - NCRS Discussion Boards
  • Steven B.
    • January 31, 2007
    • 119
    Wanted:
    Specs for the 1960 283/290 HP Cam
    Steve
    • 15610
    Re: C-1 Specs Wanted for 1960 283 / 290 HP Cam
    DUNTOV CAMSHAFT
    Part number, camshaft and indexing pin assembly, 3736097
    Lift from Chevrolet drawing number 3736098 for finished camshaft
    Tappet lift, inches, measured from point of maximum lift in cam degrees
    OE indexing points of maximum lift: Inlet 108.5 deg. ATDC, exhaust 112.5 deg. BTDC (see notes)
    ................INLET LOBE............................................. EXHAUST LOBE
    ........Opening (shown) and closing.................... Opening and closing (shown)
    Angle, Lift, Velocity, Acc. x 10, Jerk x 100........ Lift, Velocity, Acc. x 10, Jerk x 100
    0 0.26250 0.000000 -0.001600 0.000000 0.26650 0.000000 -0.001600 0.000000
    1 0.26242 0.000160 -0.001600 0.000000 0.26642 -0.000160 -0.001600 0.000000
    2 0.26218 0.000320 -0.001600 0.000000 0.26618 -0.000320 -0.001600 0.000000
    3 0.26178 0.000480 -0.001600 0.000000 0.26578 -0.000480 -0.001600 0.000000
    4 0.26122 0.000640 -0.001600 0.000000 0.26522 -0.000640 -0.001600 0.000000
    5 0.26050 0.000800 -0.001600 -0.000125 0.26450 -0.000800 -0.001600 0.000125
    6 0.25962 0.000960 -0.001575 -0.000375 0.26362 -0.000960 -0.001575 0.000375
    7 0.25858 0.001115 -0.001525 -0.000375 0.26258 -0.001115 -0.001525 0.000375
    8 0.25739 0.001265 -0.001500 -0.000125 0.26139 -0.001265 -0.001500 0.000125
    9 0.25605 0.001415 -0.001500 0.000000 0.26005 -0.001415 -0.001500 0.000000
    10 0.25456 0.001565 -0.001500 0.000000 0.25856 -0.001565 -0.001500 0.000000
    11 0.25292 0.001715 -0.001500 0.000000 0.25692 -0.001715 -0.001500 0.000000
    12 0.25113 0.001865 -0.001500 0.000000 0.25513 -0.001865 -0.001500 0.000000
    13 0.24919 0.002015 -0.001500 -0.000125 0.25319 -0.002015 -0.001500 0.000125
    14 0.24710 0.002165 -0.001475 -0.000375 0.25110 -0.002165 -0.001475 0.000375
    15 0.24486 0.002310 -0.001425 -0.000375 0.24886 -0.002310 -0.001425 0.000375
    16 0.24248 0.002450 -0.001400 -0.000125 0.24648 -0.002450 -0.001400 0.000125
    17 0.23996 0.002590 -0.001400 0.000000 0.24396 -0.002590 -0.001400 0.000000
    18 0.23730 0.002730 -0.001400 0.000000 0.24130 -0.002730 -0.001400 0.000000
    19 0.23450 0.002870 -0.001400 0.000000 0.23850 -0.002870 -0.001400 0.000000
    20 0.23156 0.003010 -0.001400 0.000000 0.23556 -0.003010 -0.001400 0.000000
    21 0.22848 0.003150 -0.001400 0.000000 0.23248 -0.003150 -0.001400 0.000000
    22 0.22526 0.003290 -0.001400 -0.000125 0.22926 -0.003290 -0.001400 0.000125
    23 0.22190 0.003430 -0.001375 -0.000375 0.22590 -0.003430 -0.001375 0.000375
    24 0.21840 0.003565 -0.001325 -0.000375 0.22240 -0.003565 -0.001325 0.000375
    25 0.21477 0.003695 -0.001300 -0.000125 0.21877 -0.003695 -0.001300 0.000125
    26 0.21101 0.003825 -0.001300 0.000000 0.21501 -0.003825 -0.001300 0.000000
    27 0.20712 0.003955 -0.001300 0.000000 0.21112 -0.003955 -0.001300 0.000000
    28 0.20310 0.004085 -0.001300 -0.000125 0.20710 -0.004085 -0.001300 0.000125
    29 0.19895 0.004215 -0.001275 -0.000375 0.20295 -0.004215 -0.001275 0.000375
    30 0.19467 0.004340 -0.001225 -0.000375 0.19867 -0.004340 -0.001225 0.000375
    31 0.19027 0.004460 -0.001200 -0.000125 0.19427 -0.004460 -0.001200 0.000125
    32 0.18575 0.004580 -0.001200 -0.000125 0.18975 -0.004580 -0.001200 0.000125
    33 0.18111 0.004700 -0.001175 -0.000375 0.18511 -0.004700 -0.001175 0.000375
    34 0.17635 0.004815 -0.001125 -0.000375 0.18035 -0.004815 -0.001125 0.000375
    35 0.17148 0.004925 -0.001100 -0.000250 0.17548 -0.004925 -0.001100 0.000250
    36 0.16650 0.005035 -0.001075 -0.000375 0.17050 -0.005035 -0.001075 0.000375
    37 0.16141 0.005140 -0.001025 -0.000375 0.16541 -0.005140 -0.001025 0.000375
    38 0.15622 0.005240 -0.001000 -0.000250 0.16022 -0.005240 -0.001000 0.000250
    39 0.15093 0.005340 -0.000975 -0.000375 0.15493 -0.005340 -0.000975 0.000375
    40 0.14554 0.005435 -0.000925 -0.000375 0.14954 -0.005435 -0.000925 0.000375
    41 0.14006 0.005525 -0.000900 -0.000250 0.14406 -0.005525 -0.000900 0.000250
    Angle Lift Velocity Acc. x 10 Jerk x 100 Lift Velocity Acc. x 10 Jerk x 100
    42 0.13449 0.005615 -0.000875 -0.000375 0.13849 -0.005615 -0.000875 0.000375
    43 0.12883 0.005700 -0.000825 -0.000500 0.13283 -0.005700 -0.000825 0.000500
    44 0.12309 0.005780 -0.000775 -0.000500 0.12709 -0.005780 -0.000775 0.000500
    45 0.11727 0.005855 -0.000725 -0.000500 0.12127 -0.005855 -0.000725 0.000500
    46 0.11138 0.005925 -0.000675 -0.000750 0.11538 -0.005925 -0.000675 0.000750
    47 0.10542 0.005990 -0.000575 -0.001375 0.10942 -0.005990 -0.000575 0.001375
    48 0.09940 0.006040 -0.000400 -0.001875 0.10340 -0.006040 -0.000400 0.001875
    49 0.09334 0.006070 -0.000200 -0.002375 0.09734 -0.006070 -0.000200 0.002375
    50 0.08726 0.006080 0.000075 -0.003500 0.09126 -0.006080 0.000075 0.003500
    51 0.08118 0.006055 0.000500 -0.004625 0.08518 -0.006055 0.000500 0.004625
    52 0.07515 0.005980 0.001000 -0.005000 0.07915 -0.005980 0.001000 0.005000
    53 0.06922 0.005855 0.001500 -0.005000 0.07322 -0.005855 0.001500 0.005000
    54 0.06344 0.005680 0.002000 -0.005000 0.06744 -0.005680 0.002000 0.005000
    55 0.05786 0.005455 0.002500 -0.004625 0.06186 -0.005455 0.002500 0.004625
    56 0.05253 0.005180 0.002925 -0.003250 0.05653 -0.005180 0.002925 0.003250
    57 0.04750 0.004870 0.003150 -0.001375 0.05150 -0.004870 0.003150 0.001375
    58 0.04279 0.004550 0.003200 -0.000250 0.04679 -0.004550 0.003200 0.000250
    59 0.03840 0.004230 0.003200 0.000000 0.04240 -0.004230 0.003200 0.000000
    60 0.03433 0.003910 0.003200 0.000000 0.03833 -0.003910 0.003200 0.000000
    61 0.03058 0.003590 0.003200 0.000000 0.03458 -0.003590 0.003200 0.000000
    62 0.02715 0.003270 0.003200 0.000000 0.03115 -0.003270 0.003200 0.000000
    63 0.02404 0.002950 0.003200 0.000000 0.02804 -0.002950 0.003200 0.000000
    64 0.02125 0.002630 0.003200 0.000250 0.02525 -0.002630 0.003200 -0.000125
    65 0.01878 0.002310 0.003150 0.000875 0.02278 -0.002310 0.003175 -0.000625
    66 0.01663 0.002000 0.003025 0.001375 0.02063 -0.001995 0.003075 -0.001375
    67 0.01478 0.001705 0.002875 0.001750 0.01879 -0.001695 0.002900 -0.002000
    68 0.01322 0.001425 0.002675 0.002500 0.01724 -0.001415 0.002675 -0.002625
    69 0.01193 0.001170 0.002375 0.003375 0.01596 -0.001160 0.002375 -0.003375
    70 0.01088 0.000950 0.002000 0.003875 0.01492 -0.000940 0.002000 -0.003875
    71 0.01003 0.000770 0.001600 0.004000 0.01408 -0.000760 0.001600 -0.004000
    72 0.00934 0.000630 0.001200 0.004000 0.01340 -0.000620 0.001200 -0.004000
    73 0.00877 0.000530 0.000800 0.004000 0.01284 -0.000520 0.000800 -0.004000
    74 0.00828 0.000470 0.000400 0.003500 0.01236 -0.000460 0.000400 -0.003500
    75 0.00783 0.000450 0.000100 0.001875 0.01192 -0.000440 0.000100 -0.001875
    76 0.00738 0.000450 0.000025 0.000250 0.01148 -0.000440 0.000025 -0.000250
    77 0.00693 0.000445 0.000050 0.000000 0.01104 -0.000435 0.000050 0.000000
    78 0.00649 0.000440 0.000025 0.000250 0.01061 -0.000430 0.000025 -0.000250
    79 0.00605 0.000440 0.000000 0.000125 0.01018 -0.000430 0.000000 -0.000125
    80 0.00561 0.000440 0.000000 0.000000 0.00975 -0.000430 0.000000 0.000000
    81 0.00517 0.000440 0.000000 0.000000 0.00932 -0.000430 0.000000 0.000000
    82 0.00473 0.000440 0.000000 0.000000 0.00889 -0.000430 0.000000 0.000000
    83 0.00429 0.000440 0.000000 0.000000 0.00846 -0.000430 0.000000 0.000000
    84 0.00385 0.000440 0.000000 -0.000125 0.00803 -0.000430 0.000000 0.000125
    85 0.00341 0.000440 0.000025 -0.000250 0.00760 -0.000430 0.000025 0.000250
    86 0.00297 0.000435 0.000050 0.000000 0.00717 -0.000425 0.000050 0.000000
    87 0.00254 0.000430 0.000025 0.000250 0.00675 -0.000420 0.000025 -0.000250
    88 0.00211 0.000430 0.000000 0.000125 0.00633 -0.000420 0.000000 -0.000125
    89 0.00168 0.000430 0.000000 -0.001000 0.00591 -0.000420 0.000000 0.000000
    90 0.00125 0.000430 0.000200 -0.003125 0.00549 -0.000420 0.000000 0.000000
    91 0.00082 0.000390 0.000625 -0.003500 0.00507 -0.000420 0.000000 0.000000
    92 0.00047 0.000305 0.000900 -0.002500 0.00465 -0.000420 0.000000 0.000000
    93 0.00021 0.000210 0.001125 -0.000125 0.00423 -0.000420 0.000000 0.000000
    94 0.00005 0.000080 0.000925 0.003625 0.00381 -0.000420 0.000000 0.000000
    95 0.00000 0.000025 0.000400 0.004000 0.00339 -0.000420 0.000000 0.000000
    96 0.00000 0.000000 0.000125 0.002000 0.00297 -0.000420 0.000000 0.000000
    97 0.00000 0.000000 0.000000 0.000625 0.00255 -0.000420 0.000000 0.000000
    98 0.00000 0.000000 0.000000 0.000000 0.00213 -0.000420 0.000000 0.000000
    99 0.00171 -0.000420 0.000000 0.000625
    100 0.00129 -0.000420 0.000125 0.002500
    101 0.00087 -0.000395 0.000500 0.003875
    102 0.00050 -0.000320 0.000900 0.002625
    103 0.00023 -0.000215 0.001025 0.000000
    104 0.00007 -0.000115 0.000900 -0.002250
    105 0.00000 -0.000035 0.000575 -0.003625
    106 0.00000 0.000000 0.000175 -0.002875
    107 0.00000 0.000000 0.000000 -0.000875
    108 0.00000 0.000000 0.000000 0.000000
    BASE CIRCLE RADIUS: Inlet .65165/.65365"; Exhaust .64765/.64965"
    NOTES:
    1. Both inlet and exhaust lobes are symmetrical including flanks and clearance ramps.
    2. Inlet and exhaust lobe difference is clearance ramp height.
    • Andy #28359
      Here are the "simple" #'s for 3736097:
      Lift: Intake .381
      Exhaust .380
      Duration at .050 lift: Intake 222 Degrees
      Exhaust 221 Degrees
      • Steven B.
        • January 31, 2007
        • 119
        Thank you very much for the long and the short of it!
        Steve
        • Clem Z.
          • January 1, 2006
          • 9427
          valve timing,intake 35/72,exh 76/31 seat to seat. this is at valve lash of .012/.018 i think.
            • 15610
            The actual duration at .050" lifter rise is 228/231 in most published sources, but it will vary a degree or so depending on the source. Duration at .050" lifter rise above the tops of the clearance ramps on both sides is 220 degrees, and this is the number you should use to compare to the .050" duration of hydraulic lifter cams. You can verify these conclusions from the data.
            The lobe separation angle is the arithmetic average of the POMLs, which is 110.5 degrees - fairly narrow for a the duration, so this cam has high effective overlap for the duration - more than is optimal for a street engine with manifolds and a typical OE exhaust system, but it was designed to win races, so the overlap is suitable for the cam's intended purpose.
            Actual lift at the valve based on the typical 1.44:1 rocker ratio achieved by SB rockers at peak lift is:
            (.2625-.008)1.44 = .366" inlet
            (.2665=.012)1.44 = .366" exhaust
            The tops of the clearance ramps can be determined by looking at the velocity and acceleration. Velocity is constant and acceleration is near zero until about .008/.012". The only difference between the lobes is the height of the clearance ramps. Note that from the POMLs to near the tops of the clearance ramps the difference in lobe lift at each angle is exactly .004".
            Based on my measured rocker ratio at low lifts of about 1.37:1 the maximum running clearance (rounded down) should be:
            .008(1.37) = .010"
            .012(1.37) = .016"
            The lobe is symmetrical - the only symmetrical lobe cam dating to that era. Even the base engine hydraulic cam from '57-'66 is asymmetrical - with milder dynamics at the closing end than the opening end.
            Although the overall dynamics of this lobe are mild, peak jerk occurs just a thou or two above the tops of the clearance ramps, so it is not wise to run "loose" clearance on this cam.
            Flow achieves maximum range when lift achieves about 1/4 of valve diameter, which is .430/.375" for the 1/72/1.5" valve set, so inlet lift is a little short, and it's even worse on 327s with 461X heads/1.94" valves.
            Effective duration is very similar to the L-79 cam (222@.050"), but overlap is greater. The Duntov cam is a very good "3/4 race cam" for a 283, but is not well optimized to a 327 with the larger valves, which is why it's not the best design for a high output 327. However, despite the Duntov lobe's dynamic deficiencies, I'm using the exhaust lobe on the exhaust side of my new design "Special Mechanical Lifter" camshaft for 327s with the 30-30 lobe on the inlet side.
            Yes, I'm using lobes from the two cam everyone thinks "I love to hate most"!
            The Duntov cam will work better on a 283 if the lobe separation is spread to 114 with the inlet POML indexed at 110.5 ATDC. This would make it essentially a mechanical lifter version of the L-79 cam, albeit with less lift.
              • 15610
              PS
              If anyone is rebuilding a Duntov-cammed 283 and is interested in trying my "Modified Duntov" cam, let me know. An off-the-shelf Duntov cam costs about $60-125, depending on the manufacturing source and retailer.
              Modifying the POMLs makes it a custom grind, and the current price from Crane for a custom grind is $250.
              Though not listed in their catalog that I could find, Jerry Clay at Crane confirmed to me that they do have the Duntov lobe masters and can grind a Duntov cam or use the lobe masters for any other design.
              Their part number for the Duntov cam is 11-3736097, Grind Number 3736097.
              The wider LSA will smooth out the idle somewhat to something a similar to the L-79 cam, but I think it can pass a PV by leaning out the idle mixture a little to roughen the idle a bit. Depending on the tradeoff one wants to make between low end torque and top end power the inlet POML can be placed somewhere between 108 and 114 degrees, but the reduced overlap should yield greater low end torque and better low speed driving characteristics, even if the inlet lobe is indexed at 114.
              With massaged OE 283 heads with 1.84" inlet valves, it should make useable power to 7200, but you will need better than OE connecting rods to rev this high without risk of busting a rod.
