C3 Rear Deck Grille Painting - NCRS Discussion Boards
  • Craig C.
    • July 31, 1999
    • 51
    I'm in the process of painting my 69 coupe its original Can-Am white and am wondering how to finish the ventilation area below the grilles on the rear deck. Should this area be blacked-out? Semi-gloss? other?
    Craig
    • 15573
    Re: C3 Rear Deck Grille Painting
    Yes, same black out as under the hood. There is a picture in the TIM&JG that shows the pattern left by the mask they used.
      • 15573
        • 11608
        Craig,
        These should help you:
        Paint the whole car white, then blackout the area under where your grilles are going to go.
        Patrick
          • 11608
          Craig,
          Patrick
          • Harmon C.
            • August 31, 1994
            • 3228
            Craig
            I would say that some of the blackout may have came off over the years in Patrick's posted picures or it is on the light end on blackout. I have seen better coverage on some original cars so I think you should try to look at some more examples.
            Lyle
            Lyle
            • Harmon C.
              • August 31, 1994
              • 3228
              Craig
              Lyle
              Lyle
                • 11608
                My car also received a fair amount of "repair line" yellow touch up at St. Louis, so it would not surprise me if yellow is on black is on yellow. Original variation, if you will.
                Patrick
                  • 11608
                  Patrick
                  • Craig C.
                    • July 31, 1999
                    • 51
                    Thanks for the replies *NM*
                    • Craig C.
                      • July 31, 1999
                      • 51
