How to determining the ratio of a rear end??
I have my original 1959 differential out of the car. I believe it is the stock NON-posi 3.70:1 rear end. Without opening the case, how can I determine if the 3.70 gears are still installed?
I tried to mark the axles and drive shaft flange and then turn the wheel and count the turns. Something is not correct. I'm only coming up with 1.80 or so (less then two) turns. I'm I doing something wrong? With a NON-posi rearend, I made sure that one of the axle did not turn during the test. Do I need to multiply by 2 to get the correct ratio?
Any suggestions? Thanks
