My 65 SB has either a high press oil pump or high volume pump installed. Oil pressure remains "pegged", even at idle until the temperature is normal and then it remains at 45-50psi at idle and "peggs" with any rise in RPM.
I want to install a normal "original" pump. (Melling 10553?)
1. What parts have to be removed before the oil pan can be removed?
2. What special precautions must be observed during the installation of the new pump?
DP
DP
