1973 A/C compressor usage - NCRS Discussion Boards
  • Craig D.
    • March 1, 2001
    • 98
    I have a 1973 coupe I bought from original owner recently. It is a smallblock car with the original A/C compressor still installed, but the belt is off and pulley bearing is seized. The compressor has the black wire with single pin connector that plugs into the back of it. I believe that this is a superheat compressor , is this correct ? Also, I have a working Non-superheat compressor without the wire receptacle in the back from a 1974 Corvette. Question I have is, can I use this non-superheat compressor in my car, until such time as rebuilding the original or does that superheat wire need to be connected for the A/C system to function? TIA, Craig
  • Dick W.
    • 10483
    Re: 1973 A/C compressor usage
    Not a major job to remove the snap rings and swap the switch for the plug. Then you have a correctly configured/functioning compressor
    Dick Whittington
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      Craig,
      I've found much useful information on this website:
      Lots of GM A/C related topics. I got much help to rebuild a A6 compressor some time ago. Use the search function and it may answer that exact question. I recall reading something there about that.
      Also check out this rebuild article. I think the A6 was used on the 73's right?
      HOT ROD is “where it all began,” as the first magazine to cover the hot rod culture. Since that time, HOT ROD has evolved into a brand devoted to everything from hot rods to restomods, barn finds to project cars and everything in between.
      Rich
