Trim tag date - NCRS Discussion Boards
Trim tag date
  • Benjamin C.
    • July 31, 1994
    • 134
    Trim tag date
    My 67 has a build date of 2/24/67. VIN # 11813. My trim tag date is G 24. Is this the same day? Is this even possible? I have good history on the car and there is no indication of the tag being changed. Everyting else on the tag is correct. If the tag was reproduced why would someone put an iffy date on it.
  • Dick W.
    • 10483
    Re: Trim tag date
    Trim tag letters begin with the first month of production, usually August. If 1967s began that month, the G is correct.
    Dick Whittington
    • John S.
      • September 30, 1997
      • 263
      Re: Trim tag date
      This is possible, if the body on your car is St. Louis built. Look at your trim tag and and check if three is an "S" prefix in your body number.
        Re: Trim tag date
        B.J. -
        Not unusual - if the body hit the first station on the Hard Trim Line (where the trim tag and VIN plate were installed) at the beginning of first shift, it would be off the line before the end of second shift. Note that the "Birthday Book" and various calculators are estimates, usually accurate within a day or two in either direction.
