Any advise on how to replace my aluminum dash insert? It seems to be braised in place. I don't really want to send it out. Thanks for the help.
C1 - Aluminum Dash Insert 61'
Re: C1 - Aluminum Dash Insert 61'
Jim, I have replaced two of these in the past couple of years. On the 61, I just carefully filed the braze or weld off the stainless trim until I could remove it. On the 62 it seemed to be spot welded and I had to drill the spots out. Not nearly as neat a job, but the end result was the same.
Once you get the trim off, the alum piece falls off. The trim is basically a press fit over the aluminum and the steel shell. It just takes a little patience to get everything back together. I did not use anything to retain the trim. Others have suggested that it should be glued or brazed. Once it's back i the car, however, it's not going anywhere. I would NOT attempt to braze or weld the pieces unless you are highly skilled.- Top
I thought that was solder
Is braze the same as solder? I'm not as patient as Ed, so I used a grinder to get the old solder (or braze?) off. For reassembly, I needed to use solder (acid core) to keep my new insert and trim in place. If you have patience, this is a do-able job. If not, both Corvette Instruments of Maryland and Al Knoch will do it for you.- Top
