66 BB distributor hold-down - NCRS Discussion Boards
  • Dan Pepper
    After adjusting timing on an L36, I found it tough to tighten the distributor lockdown bolt. I've used an "L" shaped distributor wrench and various open and box-ends, but the ridge on the intake manifold and/or valve cover is in the way and it just wont get a good grip on the bolt to satisfactorily tighten. Any suggestions for specific tools?
    Thanks-
    DSP
  • Ed Jennings
    Re: 66 BB distributor hold-down
    I've always had success with the L shaped wrenches as best I can remember, but if that won't work try a socket with a universal joint. It needs to be the built in kind, not a joint and a regular socket.
    • Dennis F. King
      Dan
      I had a professional mechanic give me a distributor tool, mfg. Vulcan, model
      TU 818. If works perfectly on my sml block. Point is, Vulcan, or SK Tools, KD Tools, Snap On and others may have the exact tool you need. Check with your local parts jobber/distributor. Don't forget the internet serch.
      Good luck! Dennis TOY-1
      • Clem Z.
        • January 1, 2006
        • 9427
        the dist tools i have are CTC 7019 and they will clear all the stuff. i have no idea what CTC stsnds for but i got them at NAPA years ago.
