Is this the correct position for the voltage regulator condenser on a 67 S/B:
Top view:
I know in Boston that I saw a number of cars get dinged on this issue, but I forgot which way it is supposed to be. Should the harness ground wire connector be above or below condensor strap on the screw.
This regulator has never been off the car, but I have removed the cover for adjusting and refinish. Don't remember if I ever removed the ground wire or condensor, maybe just bent the strap to remove the cover.
Jerry Fuccillo
#42179
Top view:
Jerry Fuccillo
#42179
