Questions re the accelerator arm and pivot mounting bracket on the firewall (2X4 car):
I know the flat arm is cad plated but can't really tell what plating, if any, was used on the mounting bracket. Cad or zinc?
Would the round rod from accel pedal through the pivot bracket have been semi-gloss black dipped?
Was the assy installed prior to paint? In Noland's photos in his Resto Guide the arms look mostly unpainted, but mine definitely had primer and blackout. JG says only that the flat arm is cad plated.
Any help would be appreciated. TIA.
