Good afternoon experts,
I've restored front coil springs and was about to install them when I hit a glitch. 2 questions.
The service and assembly manual seem to conflict with the actual configuration of this spring. The manuals place the "close spaced" coils at the top into the tower. These springs are notched at the more open end. The service manual makes reference to this notch (gripper notch) and it should be at the top.
(Spring AH 346939)
Which is more important, the close space coils at top or the notch?
I've also just rented a spring compressor. It appears the centre rod will push too far into the tower. Can the lower a-arm be used as a point to secure the lower side of the coil. it looks as though the spring needs to be tightened with the nut at top.
Thanks as always.
Michael B.
(Spring AH 346939)
Thanks as always.
Michael B.
