C2 1965 Hard Top Side Bolts - NCRS Discussion Boards
  • David H.
    • October 25, 2006
    • 92
    Also, while I'm on the deck, the left side bolt came with the car and I assume original. The right bolt is a repop that has a slight flat 'dimple' front & center. Does the left hand bolt appear correct and original?
    Thanks again,
    Dave
    David Hobby (46447)
    Re: C2 1965 Hard Top Side Bolts
    Dave-----
    It looks right to me. This particular bolt, GM #3727973, was actually used for many years on Corvettes. As a matter of fact, it's still available from GM. I suspect your "repop" is actually a later GM piece of the original part number. The differences from the original are really quite minor.
    • David H.
      • October 25, 2006
      • 92
      Thank you Joe. I was curious. The 'repop' is actually pretty much identical. On close examination, I noticed it had a flat 'dimple' - that being the only difference I could tell. I suspected the other was likely original. I found it 'lost' down a cubbyhole in the car and fished it out and cleaned it up.
      Dave
      David Hobby (46447)
