I replaced the right side trailing arm assy last year on my '67 L79...it went pretty smooth. Now I am removing the left side trailing arm and have the following two problems:
1. I can't remove the strut rod at the camber adjustment end near the differential. I removed the camber nut and I can turn the camber bolt but I can't get the camber bolt out to remove the strut rod.
2. I can't remove the half shaft at the differential end. I loosened the U joint nuts near the differential but I can't get the U bolts off to remove the half shaft. The U bolts are frozen.
Any advice is greatly appreciated.
Happy New Year,
Mark
Happy New Year,
Mark
