C1 '58 Bellhousing / Exhaust Man. Foundry - NCRS Discussion Boards
  • Ted S.
    • January 1, 1998
    • 747
    Were the cast iron bellhousings and exhaust manifolds cast at the same foundry as the flint assembled engines came from? I'm trying to understand if there's a relative relationship between cast dates for the engine, bellhousing, and exhaust manifolds. Thanks in advance. Ted
  • William C.
    • May 31, 1975
    • 6037
    Re: C1 '58 Bellhousing / Exhaust Man. Foundry
    Same foundry, but not in batches or sequentially, every day several thousand engine blocks, exhaust manifolds, and a lesser quantity of Bellhousings were produced and trucked as single items (a truckfull of blocks, a truckfull of manifolds etc) to the Flint Engine plant where they were dumped into a "last in first out" inventory system. Parts were then taked randomly from this pile and loaded onto the appropriate machineing lines to work towards final engine assembly. The whole engine machining and assenbly process was not lengthy, not was any of the inventory date prioritized.
    Bill Clupper #618
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      ted... I don't believe...
      ...58 exhaust manifolds had cast date markings.
      • William C.
        • May 31, 1975
        • 6037
        If they did, they are on the inboard side *NM*
        Bill Clupper #618
        • Ted S.
          • January 1, 1998
          • 747
          Re: ted... I don't believe...
          Mine had what appears to be month and day. No year.. They are on the inboard side.
            Ted -
            Not having a year designator is quite common on exhaust manifolds; just the month letter and number for the day.
