Steering wheel disassembly/ more from 62 Puzzle - NCRS Discussion Boards
  • Eric
    This is a simple one! I am currently in process of removing the steering wheel assy so I can restore the signal arm contacts per a prior article in the Restorer. It seems that the horn cover should just pull off, however, mine is not that cooperative. I thought I would ask experience before I rush in as fools are known to do. Also, any other tips in this area would be appreciated. Thanks!
  • J Grantham
    Re: Steering wheel disassembly/ more from 62 Puzzl
    The horn cover (button) just pops off. Use some penetrant and then some popsicle sticks wedged under the button and it should come off.
