67 bb upper rad support brackets - NCRS Discussion Boards
  • Phil P.
    • April 1, 2006
    • 409
    i'm on car # 2 and have a question on upper rad support brackets---i purchased paragon bolt kit and it has 2 different length bolts with the tr and (wb , it is shorter) markings---also has the star washers---checked the aim and it's clarity on the bolts is un-clear to me as mine only shows pass side outboard bolt---with a lock washer and "p" washer----were they born with split or star washers---thanks for any and all input---phil---when i took the car apart all the bolts were "looked to be" the correct length with a large "fender" washer and a split lock washer
