67 L79 heater hoses - NCRS Discussion Boards
67 L79 heater hoses
  • Randy R.
    • March 1, 1983
    • 477
    67 L79 heater hoses
    I am assembling the hoses in my engine compartment and have a few questions:
    1) The JG says the heater hose clips are a green oxide color. What can I use
    to replicate this finish?
    2) What are the approximate lengths of the heater hoses?
    3) A previous post states that the nipples coming out of the heater core are
    a silver aluminum color. Mine are a plain brass color. Which is correct?
    4) The clamp kit I have has red spring clamps for the 3/4 inch hoses and
    yellow cad spring clamps for the 5/8 inch hoses. Is this correct?
    Thank you for your time.
    Randy
    Re: 67 L79 heater hoses
    Randy -
    The heater hose clips are VERY dark green - I'd call it dark gray; a dark shade of cast-blast might work if the finish on yours is history.
    Install the hoses and cut them to length when the routing looks good to you.
    Heater core nipples are brass.
    Corbin clamps sound fine.
    • Randy R.
      • March 1, 1983
      • 477
      Thank you John.
      I will have to dig into my collection of spray cans to see what I can come up with.
      Randy
      • Mike M.
        • September 30, 1999
        • 710
        Lengths taken from Doc Rebuilds catalog
        63-67 327 exc AC 5/8 hose 37", 3/4 hose 19", 16" & 3".
        66-67 with AC 5/8 hose 42" & 3" 3/4 hose 23", 16" & 3"
        • Geoff C.
          • May 31, 1979
          • 1613
          Lengths are from GM rounded to nearest inch
          Never had a problem with those lengths for fitment.
          • Randy R.
            • March 1, 1983
            • 477
            Re: Lengths are from GM rounded to nearest inch
            Thank you gentlemen
            Randy
