53 to 60? Used cloth tags. 61 to 63? Cardboard tags?? Later C2's metal tags?? All having part number and dates. Need in-put with more info needed???
Seat Cushion tags
Re: Seat Cushion tags
Roy,
My 1962 #13078 (build date 6-22-62) has the following information on black cardboard tags:
Driver's back: MSWBP 2 10 61 / J A2F-1114-C / (no part #)
Driver's bottom: MSWBP 2 17 61 / J A2E-1113 / 3782958-6
Pass back: MSWBP 2 10 61 / D A2F 1124-C / 3819176
Pass bottom: MSWBP 2 17 61 / E A2F 1123-A /3782958-6
These seats are original, still with the factory red upholstery. Note that both backs and both bottoms bear the same dates and would seem to be 1961 model frames, not to say that there was any difference. The driver's bottom tag has some previous water damage, is faded to white cardboard and the letter following 1113 is illegible.
The slash marks between the numbers above indicate separate lines on the tags. I would post a photo but not sure how to do.- Top
Re: Seat Cushion tags Justin
Roy, my '57 original seats had cloth tags on the seat bottoms and cardboard tags on the seat backs. May have the order reversed. If I get a chance today, will check my files and post the part no.s Gary....NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
'57 Seat Cushion tags
Roy, my '57 VIN 300X had cloth tags on seat bottoms (water soiled beyond reading #'s) and oval elongated black cardboard tags with raised stamping on seat backs. Cardboard tag stamping per the following:
BP 7 30 56
M.S.&W.A. 160A
3740252
Part no. on the other tag is 3740251
Regards, Gary....NCRS Texas Chapter
